Ok, to get 2ohms (is your amp 2ohm stable) you need to wire them like this...
If your amp is not 2ohm stable then wire them like this, for an 8ohm load...
And an amp for 200bux, than is 2ohm stable, and is around 500watts, i suggest the USX 600D @
http://www.thezeb.com for $160, it will push your subs 375x1 @2ohms. This is a D class amp, and will not drain your alt. as bad...
