Sub Problem
Post all your Nissan electronics, car audio and stereo questions here!
GrilledCheese33
Car: 2008 Nissan Xterra
1972 Yamaha R5
2017 Sea Doo Spark Trixx
So ya my sub quit on me yesterday so I pulled it out of the box to find a connector had wiggled off, so i hooked it back up and nothing. Turns out that if you push the speaker back in toward the magnenet, it starts to work but after hitting a few times it stops. Any ideas?
EW
Car: 95 S14
98 Cobra
06 F150 supercrew
Bad voice coil. Buy new woofer.
GrilledCheese33
1972 Yamaha R5
EW wrote:Bad voice coil. Buy new woofer.
Thanks. I figured that. Now I gotta hold off to replace it b/c my insurance is due soon. It sounds so bad w/o bass in the car LOL. but i'll live. On another note, good recomendations on a bang for the buck subwoofer? I have a 1 12" setup w/ an alpine single channel 350 watt amp. Suggestions on a sub and a cheap place to buy it would be appreciated!
Thanks!
qsiguy
Car: 1994 Infiniti Q45 Turbo
There is also a possibility of a loose tensil (spelling?) from the speaker terminal to the cone. You may be lucky and just need to resolder one or both of them. When you push in the speaker you could also be causing that wire to reconnect. I've seen that happen numerous times. They get worked pretty hard from the constant cone movement and if the solder joint isn't really secure it can come loose.
If you pull the speaker out of the box you could turn it on and just wiggle the tensil wire on the back of the speaker to see if that makes it come on. Could save you from buying another speaker.
Looneybomber
Car: 02 explorer sprt (grn)
10 G37S (white)
GrilledCheese33 wrote:good recomendations on a bang for the buck subwoofer?
http://www.tcsounds.com/db500.htm
They used to be 75 +shipping. Now they're 109 shipped.
GrilledCheese33
1972 Yamaha R5
qsiguy wrote:There is also a possibility of a loose tensil (spelling?) from the speaker terminal to the cone. You may be lucky and just need to resolder one or both of them. When you push in the speaker you could also be causing that wire to reconnect. I've seen that happen numerous times. They get worked pretty hard from the constant cone movement and if the solder joint isn't really secure it can come loose.
I checked those first, they are fine
Looneybomber wrote:http://www.tcsounds.com/db500.htm
Thanks for sharing, I think i'll go w/ that
Looneybomber
10 G37S (white)
GrilledCheese33 wrote:Thanks for sharing, I think i'll go w/ that
Let me know how it works out for ya. I'm a big fan of TC-Soundss
GrilledCheese33
1972 Yamaha R5
Looneybomber wrote:Let me know how it works out for ya. I'm a big fan of TC-Soundss
will do. I should have it in a month or so
