66mgb wrote:When should these be replaced for p/m? Is this terribly difficult to do? I see that Joe sells a kit for this.I should probably change the bypass hoses also.For all the above - can these hoses be sourced in silicone? While pricey, I understand they tolerate the heat much better.
How many miles ? 187K ? Yup.
It's very tedious, and you have to get your hands into some tight places.The knock sensors really should be done at this time, just like the fuel hoses.
I would take all the hoses to a rice shop and try to match things from their stock for silicone, somebody tried it here but don't remember how it went.Search.
Might need an IAC gasket too.
PS: it would be a good time to flip the plenum over and clean it out real good with some Purple Power, and clean out the EGR passages too.
