xekushnr »
https://forums.nicoclub.com/xekushnr-u16901.html
Mon Jul 04, 2005 8:18 pm
correct, you wont need to run the RCAs up front, they will only be travelling a small distance from the LOC to the amp. there really is no specific way to do it, i usually just splice the positives and negatives from each channel together and hook those wires up to one speaker as it takes less time and less wire. and if you want a clean install, you probably wont want to splice the LOC in by the speakers, because you will see the box. trace the wires from the speaker until you find a spot you can stash the LOC in. it will look a lot nicer.
