I hooked up my sub, power wire (not routed through the car, wanted to test fire first), got all my speaker wire stripped and stuff like that... Went from the positive terminal of the battery to the power port on the amp, then grounded the GND portion to the metal thing in the back... Its like strut brace
Since I have "speaker level inputs" on the amp I figured I could tap right in where it goes from the bose amp right to the actual speaker, into the amp..
I tried and I got no sound
Theoretically this setup should work... PLEASE help!
