Hi guys,
New to this forum .. and my first post..
Over here in Scotland the Infiniti is a rare and special breed...
I bought my M30D Premium S in September2011 and there are still fewer than a dozen (M's) on the road in Scotland.
The M is by far the most enjoyable car i have had for those longer journeys.
I have a Jaguar XKR for funtime and have driven all the usual "German" suspects over the years..
I am having difficulty getting the sound settings just right on the Premium Bose set-up.
The bass level is not "meaty" enough at my prefferred volume without sacrificing the higher end ..... "muddy" is how other forum members describe and I agree..
The car is under warranty .. so the short-termI plan on installing some subs in the boot (trunk to you guys).. and will replace the full set-up in a couple of years..
Having read a few of the very useful wrtie-ups I thought I would create a
"How To" for the 2012 "M & gathering photos for the task as i go along.
I plan to use a PAC OEM2 Line Converter to bridge the Ballanced signal input to Standard RCA Output
Set-up
x1 Alpine MRD-1005 Class D Mono Amp (at 2-ohms)
x2 Alpine SWR-1222 (2-ohm DVC Subs) in Matching Alpine Ported Enclosure
The voice coils are wired Parralell and Subs wired in Series
to give 2-ohms at the AMP.
Zero-gauge Power and Ground Cables; 8-gauge Speaker Cable (150-Amp block)
2-Farad CAP
90% done.....
Removed Trim Panels from Boot (Trunk)
Located Bose Amps under Rear-Deck
Located Low-Level Signals (using "Rear" L&R) and tested using DMM...
Cables Tapped-in at the AMP-"input" side
Low-level Signal Cables soldered and insulated with pvc tape
Power Lead Connected to Battery Post; which is positioned in the boot
Seperate Earth-points Secured for AMP, Cap and PAC-OEM2
Switched 12V+ power for -OEM2
Final testing of the wiring and some tydying up to do..... likley put her all back together this weekend
i will keep you posted
Could someone advise me how to upload photos?
regards
flikz
