sub-frame collars
captainluigi
Car: 1996 q45t
anyone no of collars of material other than aluminum? poly? hard rubber? i'm just thinking i will not like the noise increase.
NOR*CAL 916
Car: 1994 infiniti q45
polyurethane bushings i dont know if they make them for the Q45 but thats your best bet for aftermarket.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The increase in noise is NEGLIGABLE at best. maybe 5% increase at worst.
Youll like em, trust me. its a 1 hour install for the subframe collars vs 5-8 hours for bushing install.
Trust me, I am ultra sensitive about noise and vibration increases and you wont be disappointed.
Look at it this way. you still have a rubber bushing in place, so going top to bottom you have collar-rubber bushing-collar, so you still dont have any noise transferred.
captainluigi
Car: 1996 q45t
o.k. then. i'll order today. the ones for a 300z are the correct ap?
elwesso
2007 BMW M Coupe
yeah 300zx and 240sx are both the same.
PachoC
Do you have any instructions on how to install these?
elwesso
2007 BMW M Coupe
Yeah..
1. Jack rear of car up2. Place jack under subframe (2 jacks may make it easier)3. Unbolt 4 nuts holding subframe to chassis.4. Lower just enough to place the top collar on (sliding it on). 5. prior to installing bottom nut, place lower collar on.
Hardest part about this job is fighting the bolts and nuts off if you dont have air tools. if you have air tools it will be cake.
PachoC
Great!Tks.
DrewQ45
Car: 1990 Infiniti Q45
once these are installed, does the car sit slightly higher? Any good sources for these?
elwesso
2007 BMW M Coupe
no it doesnt change the ride height of the car. Thats because the spacers take up SLOP that is there. Basically theres a gap between the top of the bushing and the frame of the car, and the spacers just sit inside that gap.
captainluigi
Car: 1996 q45t
sourced mine on ebay BUY NOW. $44. del. thru usps free. on ebay motors search ''subframe collars''. as wes said the 240 or the 300zx are correct ap. bueno suerte
PachoC
Is there any chance you could post a picture of the collars? A picture once installed will be great too...Tks.
captainluigi
Car: 1996 q45t
well documented. SEARCH!
