Sub-frame bushings
jacob360
Car: 2 S13 Coupes
I see that Whiteline sells polyurethane sub-frame bushing inserts to save the hassle of replacing the bushings, but what if I do want to replace the bushings entirely? Does anyone make polyurethane subframe bushings for an S13, or can I maybe stack the Whiteline inserts?
corn322
Car: 1993 240sx
someone has aluminum bushings, I dunno who makes them. I remember someone on here got some for his/her car, do a search... maybe you could find the person.
Exar-Kun
Car: 2005 350Z
I have them. I havent installed them, because it rquires me to remove my sub-frame, burn and cut out the old bushings, and try and manuver the press around the sub frame to put the new ones in.
SPL parts and a few japanese mfr. make alluminum sub frame bushings.-chet
jacob360
Car: 2 S13 Coupes
SPL parts has alot of good stuff. Those prices on the TC rods, adjustable arms and hard tie rods are for both sides right?
APEXi240
Car: 08 Nissan Versa S hatch
Nismo makes the sub-frame bushing too...although they are rubber. I have yet to install mine for all the same reasons Chet stated. I do need them badly though.
ucfz31s13
Car: Business/Networking/Web
Depending upon how shot your bushing are, you might just want to get the sub-frame spacer/collars from SPLparts.com.
Instead of a full bushing, its 'squishes' the stock bushing and makes them stiff/stiffer. The top collar is notched for ease of installation so you don't have to drop the whole subfrace, just loosen.
85$ for the set.
lataz
z
SingleCamSam
Aluminum subframe bushings. My *** hurts already.....
corn322
Car: 1993 240sx
or instead of spending $85, go to home depot and get a handfull of washers. I can't remeber exactly what size washers... there's a thread on FA about it, do a search there for "drift washers"
