QR25DE wrote:Well there's a lot of different things to factor in:
1. What kind of music do you listen to?
1 10" may not be enough boom for you. Typically 10s are for a more "punchy" bass for rock and pop music. If you listen to rap/hiphop you probably would want to go with a single ported 12". It all depends on your other gear as well. How much trunk do you want to use up? What amp and head unit are you using? And so on.
I run a single ported 12" Mach 5 Audio sub. It's was cheap and i grabbed a ported bassworx box from BestBuy to finish it off. I listen to mostly rap music and it hits the lows nicely.
You'll want to get an after market head unit with preouts. You'll need an amp and while you're at it you may want to upgrade the speakers. I have stock speakers and they're good enough for me after some tuning.boston702 wrote:QR25DE wrote:Well there's a lot of different things to factor in:
I listen to manly rap and r&b i think you got the same AC i have if you do you think you can send me a pic of you set up it would be alot of help i wanted a custom fit box but all them take up alot of room i want room for some of my military gear and i havent bought any componets yet also will the oringinal head unit work ok with that set up?
Lol! Yeah, Groceries still fit, sometimes... lolIBCoupe wrote:Heh. Trunk? What trunk?
nogears909 wrote:heres what i made for mine just a single 10" cuz i only listen to rock and metal. could prolly do it with a 12" to. I had to do mine this way so i could still fit my hockey gear.
^^^^^nogears909 wrote:custom-fit-12in-fiberglass-subwoofer-bo ... 57398.html
exact same thing i did
took me about a week, prolly could have done it a bit quicker but ya, first time working with glass so wanted to take my time to make sure i did it rightMattv609 wrote:^^^^^nogears909 wrote:custom-fit-12in-fiberglass-subwoofer-bo ... 57398.html
exact same thing i didgreat searching urs looks good too.. Take u long to do? Was ur first time wit glass too?
QR25DE wrote:Lol! Yeah, Groceries still fit, sometimes... lolIBCoupe wrote:Heh. Trunk? What trunk?
mine still fits alot you just cant take down the back seats. I fit a s*** of stuff in this car b4 soooo yeaQR25DE wrote: Lol! Yeah, Groceries still fit, sometimes... lol
yes plenty of ppl.... just need the sub and the right amp for the sub... AND... a hi-lo switch or (adapter) its called that allows you to connect the amp to the stock head unit..... now only thing u need 2 know is that you wont get 100% wattage from your sub.. because the stock headunit does not distribute alot of watts...but its still goood and ull get alot of base...RandyFool wrote:Has anyone installed a 10in sub with an oem bose system? can it be done????
I have the stock Bose with and aftermarket amp and 2 - 10" subs. Like mattv said you'll need a hi-low converter to do the install. I made a thread about it in the av forum. I'll try to find it and link it. Don't skimp out on the converter though. Be sure you get a PAC unit and NOT anything else. Somebody used a different converter and it didn't work. When he went and bought the PAC unit it worked. You can also get it with an adjustable gain control for both channels.Mattv609 wrote:yes plenty of ppl.... just need the sub and the right amp for the sub... AND... a hi-lo switch or (adapter) its called that allows you to connect the amp to the stock head unit..... now only thing u need 2 know is that you wont get 100% wattage from your sub.. because the stock headunit does not distribute alot of watts...but its still goood and ull get alot of base...RandyFool wrote:Has anyone installed a 10in sub with an oem bose system? can it be done????
