I used to have the same problems and got REAL fed up with it, until I realized stay away from nicoclub.com and use http://www.nicoclub.com.Yorb wrote:gayass nico just lost my long post because it LOGGED ME OUT while i WASNT LOOKING.
okay so i'll be brief this time: thanks for the replies, keep em coming while im at work today.
that lanzar amp is attractively cheap, and very strong for the price if what you say is true.
since i'm running 250W subs in parallel (2 ohm load?) and the amp says "1 x 2000 Watts Max at 4 Ohms Bridged" doesnt that mean each sub will get 500w max? guess i'll just have to be careful not to blow the subs? =)
thanks for the suggestion though its at the top of my consideration list now.
Profile is basically flea market stuff, it's just a 1/2 step above Rockwood (it just trying to sound like a brand you know)Yorb wrote:... I was looking at the Profile AP1000M (500 x 1 @ 2 ohms RMS), but I've never even heard of Profile so I was worried ...
HOly carp! Where is that amp for sale that cheap? That would be a pretty amp to power a CV 18" StrokerRex wrote:Or go with the Hifonics Brutus, which is marked down to $249, thatr's a big nasty amp. Mono Brutus Series Power Amplifier1 x 450 Watts @ 4 Ohms1 x 900 Watts @ 2 Ohms1 x 1500 Watts @ 1 OhmsBass Remote with Blue LED Power On & Diagnostics IndicatorD-Class DesignUltra-Fi MOSFETSZeus EVXP (Exponential Vari-Power Supply)SPC - Simpatico Coil DesignHSMD - Hifonics Surface Mount DesignFully Adjustable Accu-Cross CrossoversPWM MOSFET Power SupplyLine Output for Amplifier Daisy ChainingVariable Bass EqualizationVariable Sub-Sonic Filter4 Gauge Power ConnectorsAdditional High Speed MOSFET Output DevicesMaxi-Fuse
Reading all the info would indicate that amp for that price at http://www.cbrstereo.com ... a value in reading .PoorManQ45 wrote:HOly carp! Where is that amp for sale that cheap? That would be a pretty amp to power a CV 18" Stroker
I ain't never did not learn how to read that ther and I is doin just fine is can bee.Rex wrote:
I'm confused .Yorb wrote:The verdict is in, they are indeed 10W3-D4 subs. 4-ohm dual voice coil. And they are wired in series, which according to JL should present a 4-ohm load. And according to PG, my amp can do 300W x 1 at 4 ohms bridged, which makes sense. They are getting about 150W each.
So, if I keep them wired in series I need to find an amp that can do 500W x 1 with a 4-ohm load. Right? The Orion 6002 says 600 x 1 mono, doesn't give a load. You said 2 ohm though, correct? So that probably wouldn't be any better than the amp I have.
The Brutus BX1000D is only $229 at CBR, and it claims 1000W x 1 at 1 ohm. Wouldn't that give me essentially 500W per sub? Overpower, but if I ever want to upgrade my subs it would give me room.
Hmm...
means they have 2Ohm voice coilsYorb wrote:I don't know much about impedance and voice coils and stuff, but alls I know is they say 4-ohm, dual voice coil. Four ohms per sub. The manual for the subs has wiring schematics that say for two of the subs, wiring them in series presents a 4-ohm total load, whereas wiring them in parallel presents a 1-ohm total load. Does this make sense?
