elo240 »
https://forums.nicoclub.com/elo240-u42142.html
Tue Jul 15, 2008 1:43 pm
I have a aura stage 2 amp I'm going to use for my sub.Here are the specs.2 Channel Amplifier 2 x 75 watts into 4 ohms, 1 x 225 watts bridged mono into 4 ohms, 0.1% THD from 20 to 20kHz. 85 dB signal-to-noise ratio. 20 Hz - 20 kHz frequency response.
My question is which is best, run a single voice coil sub and bridge the amp or use a dual voice coil sub and run it in 2 channel mode. I will be using a 12" sub but haven't decided on the brand.
