If you're going to do that, then definitely get JL. You can find JL 10W3v3s on ebay for around $150 w/ buy it now and you can pick up a 500.1 amp for around $200 on ebay as well. If you can't trust ebay, http://www.onlinecarstereo.com has the W3v3 for $165 and the 500.1v2 (which is 2nd gen 500.1) for $375. I've bought from them and they are very good. Hope this helps.tarek wrote:Well, prices here are crazy. When I eventually get the AC it's going to be from the states because the price difference is at least $5000 (probably more) out the door. If I can find a good price on some JL Audio stuff from the US, what I can always do is ship it to the nearest UPS store in Bellingham, WA and drive down and pick it up. It's about a 45min-1hr drive from Vancouver so it's not horrible. That's what I'm going to do when I do buy the D3 or Kenwood 5120, because they are so ridiculously marked up here. I guess the smart thing to do would buy the car, HU and sub/amp all from the states and pick them up all at once...save myself time and money!
OK, I'll try to chime in...tarek wrote:I've spent the last couple of hours (procrastinating writing an essay) looking at JL Audio stuff on ebay, and they are a LOT cheaper than at stores! I see that the 10W6v2 is around $90 more than the 10W3v3. Is the 10W6 significantly better than the 10W3?
I looked at the specs on crutchfield (and honestly I don't know what they all mean) and it looks like the 10W6 can handle 150W more than the 10W3, but since I'd pair them up with the 500/1 amp it wouldn't really matter. The 10W3 is 100 - 500W RMS while the 10W6 is 150 - 600W RMS, but I'd only be putting a max of 500 through them anyways. Also, the frequency response for the 10W6 is slightly better (23 vs 25) but the sensitivity is lower (83.7 vs 84.87). Anyways, these numbers really mean very little to me, and I know that a sub is more than just its paper specs.
Anyone have any experience with both these subs that can chime in to the differences when given equal power (500W)?
Regarding SQ, anytime a sub is in a sealed box, you will have tighter bass... Iwould say it depends on what type of music you listen to. If you want tight bass, then go with the JL in a sealed box.. if you listen to hip hop and want booming bass, then by all means go with the T1.tarek wrote:Hey rjdmmfl1,
Thanks for the advice. I've heard others who have said the same thing about infinitys subs/amps and that's why I came here to you guys for advice.
Now when I was looking on ebay for the RF subs you recommended, I saw that the T110D2 sub sells for about $165 brand new. Compared to about $240 for the 10W6, that's a $75 difference! And if you say that it'd destroy a 10W6, that's a pretty nice deal. It's also only $30 more than the 10W3s, so it seems like that's making it pretty high on my sub list! I'm definitely leaning towards this now, just got a couple of questions.
According to crutchfield they seem almost identical in specs (to the 10W6). The T1s do need a bigger box (almost a full f^3 bigger if going ported), but honestly I'm not *that* space conscious...I obviously just want to make the most with what I've got, but if I can find something better and cheaper, well that'll win out. The only difference I see (specs wise) is that the frequency response for the T1 is 35-250, while the W6 is 23-250. Being a sub shouldn't it be as low as possible? 35 seems pretty high compared to most subs I've looked at (again the #s means quite little to me, I just go by what I read on forums and such).
Also, even if the T1 can hit louder, how do they compare in SQ? Like I said earlier I don't need anything which pounds down the block (although I really wouldn't be opposed to it having power for when I want to crank it up), but I am trying to be very SQ conscious. Ideally of course I'd want high SQ & SPL. Is the T1 in a ported box competitive with the W6 in a sealed box with regards to SQ?
About the amps, I think I'd still prefer the 500/1 as opposed to the T5001BD. Reason being that the 500/1 has higher specs and is only $30-40 more on ebay. And if I did get the T1 with the 500/1 it'd still be under my budget which is great!
Thanks for your help btw, I think I'm decided on getting a Kenwood 5120 even if it is a couple of hundred more. I really like the idea of the simplicity and speed of the UI, and more accurate/faster nav system. Thanks for posting about it earlier.
It needs air and want air to breathe. Its not like other subs! You can do a P3 in a sealed box, but no true audiophile and RF expert would suggest putting a T1 in a sealed box.. actually, when they first came out, there weren't any specs for a sealed box for the t1 or T2! It really doesn't want to be in a sealed box!tarek wrote:Wow that's crazy about the T500-1bd. I like how the one guy says that the guy at his local shop has never seen one less than 850RMS. For the price they're selling at that's a steal. Out of curiosity why do you say not to mix and match sub/amp? I didn't think it'd matter what brand goes with what, only the power that's going into the sub...
And a T1 in a sealed box is a big no no? I tried to find reviews and people said it pounds away in a sealed box, but doesn't mean it sounds great I really like that it's $70 less though, but I would really want to put it in a sealed box. I do listen to rap and hiphop, but I also listen to a lot of rock and punk, and even pop on occasion. All of which a ported box might be a little off/a little loud for...hmmm
decisions decisions I appreciate all your input in this rjdmmfl1
OK, the first one is inconsistently labeled... regarding the second two...tarek wrote:Well, since the T1 really doesn't want to be in a sealed box, I'm back to eyeing down the 10W6 again. The reason I was asking about mix and matching, is that earlier you said the 10W6 can easily handle 700W RMS. Now if the T500-1bd is very underrated and at 2 ohms it's actually putting out 700, then I'm making full use of the sub, whereas the JL Audio 500/1 is rated at 500W from 1-4 ohms. Plus, the T500-1bd is quite a bit cheaper on ebay than the 500/1 (up to $70 less).
I was hoping you could clear something up for me on some of the listings I'm seeing on ebay. They all seem to have different pictures, but claim to be the same amp? Here're 3 examples:
http://cgi.ebay.ca/NEW-Rockfor...wItem http://cgi.ebay.ca/ws/eBayISAP...h=020h ... AP...h=002
The last one there is the only one which matches the picture on crutchfield, and claims to be an authorized Rockford Fosgate dealer. It's also the cheapest. The specs for the first one seem to be all wrong, so maybe it's just mislabled or something? But the 2nd one seems to be all right, but the picture is way off unless I'm missing something. I just find it really weird
Beatrice, I think you and I are on the same page... however, just to clarify, out of the box, a W7 would kill a 12" Rockford T2, but after break in, that would not be the case. The JL W7 and the Rockford T2 (not T1) are very cloosely matched subs, with the Rockford T2 being able to handle a bit more watts RMS than the W7. Its just that the T2 needs about 1 month break in time! To compare your W7 to your previous Rockford 12"'s (which I'm sure were NOT T2's) is like comparing apples and oranges!Beatrice wrote:I agree with rj on not mixing and matching. Usually companies will produce their amps specifically for their subs, and usually they are perfectly paired. JL does have a reputation for being a little more conservative, so usually it's safe to step up the amp in any sub/amp combo they recommend.
The 10W6's power handling isn't that big a step up from the W3's, so it's safe to assume that they will be sufficiently powered, but having owned a 12W6 (which has almost the same exact power handling specs as the 10W6), I can tell you that it just felt underpowered. I mean, don't get me wrong, that combo will bang the **** out your car, but it just wasn't enough for me. Even my W7 *could* be louder Then again, like I've said in other posts, I'm a SQ +SPL nut... to an extreme degree, so... But if you're not as nuts as I am, I am 100% certain you will be completely satisfied.
If you do go with the W6, remember to get the 10W6v2. The regular W6s have a slightly different coil design and are also slightly weaker. I would also recommend getting the 500.1v2 as well as the thermal properties of the v2 are much better.
As for mixing with the RF... There's nothing wrong with going that route. It probably is a better fit for the W6 as far as power goes... I just don't like crossing streams
