Stuttering/Bucking under very light acceleration
theomajigga
Car: 2002 Infiniti QX4
Hey guys,
I've got an issue that is driving me crazy. Searched a bit and just want to see what you guys think.
Open loop: No issue./ No bucking.
Closed loop: Under light acceleration the (10-15%) the car bucks like a pissed off bull. I can floor it @ a stop and it doesn't buck, just goes. It's driving the girl crazy and I want to fix it.
MAF?? TPS???
theomajigga
Just checked the TPS with a multi. Tested out fine.
So MAF???
barnaclebob
Car: 2001 Pathfinder LE
2011 Altima SR
Thats what I would start with. I had abnormal throttle responses when mine was going bad but I also had left/right bank to lean codes. The car would lag and not have power, then the RPM's would surge as i pushed the pedal further. After it warmed up, this went away so I lived with it for awhile. Eventually it started losing power on the highway going up hills which was unsafe so I replaced the MAF. No problems since.
If you replace the MAF search on here for the thread which gives you the maxima part number, same thing for $120 instead of $400. My MAF had a dusty looking buildup on it that wouldn't come off so maybe if yours looks the same it is bad too.
theomajigga
Not the MAF. I unplugged it and it still acted the same. How many signals does the car get from the TPS? Does it use all of them?
barnaclebob
2011 Altima SR
theomajigga wrote:Not the MAF. I unplugged it and it still acted the same. How many signals does the car get from the TPS? Does it use all of them?
How does unplugging the MAF rule it out? I haven't heard of that before and am curious. I can't remember if I tried that or not when mine was bad.
atraudes
Car: 2001.5 Infiniti QX4 4WD
It's the same principle as trying to rule out a bad ignition coil. If you unplug it and the behavior doesn't change, the unplugged part is bad. If there is a change, it's at least partially doing its job :chuckle:
theomajigga
Bump.....
bgruhn76
Car: 2000 Nissan Pathfinder SE Ltd 2WD - Black
I have 3.3L in my 2000...has distributor...does the 3.5L have one? I had same issue, and replaced mine. Fixed it right up.
Hawairish
Car: 2004 Nissan Pathfinder SE 4WD
Is it throwing any codes?
theomajigga
O2 code. And I don't think it has a distributor.... I guess I haven't had a look!
barnaclebob
2011 Altima SR
Which O2 code...
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
bgruhn76 wrote:I have 3.3L in my 2000...has distributor...does the 3.5L have one? I had same issue, and replaced mine. Fixed it right up.
No distributor in the 3.5L. Ignition coils.
You unplug the MAF in hopes that things change.
If nothing changes when you unplug the MAF, then that is your likely problem.
