stupid yet important question
drift-sx
ok as you may or may not know i have been painting my interior so the other day i removed my rear view mirror to paint in and there was a tiny screw in the back. so i took the screw out (hoping it somehow would remove the mirror for the holding thing) but insted the whole unit lost all its frictioni guess now the mirror jsut dangles freely and is of no use. i tried to put the srew in but it doesn't seem to have anywhere to go into i was jsut wondering if there was a trick to getting this in.thanks.
Holisticbeatz
You insert it back in the same way you got it out? Use a magnetic screwdriver maybe?
drift-sx
no it doesn't have any place to screw into it jsut goes in and out freely its quite odd
Holisticbeatz
I'm stumped..
jrc90240sx
you might need to hold the mirror in the same place it was in when you took it out. sounds like it might have movied (the thing that holds the mirror in place)
S13 Power
just get a new one from the junkyard. or get one of those broadway mirrors. My friend had it on his accord and its ok, u could see fairly well to the sides without looking to the side mirrors.
drift-sx
thanks guys
There's a nut on the backside - When you removed the screw, the nut fell off inside and now there's nothing for the screw to "grab" onto.
You'll have to disassemble the housing and replace the nut.
drift-sx
yeah i figued that out but it istn; as easy to put back together i had to melt the pieces of the sides on the front quater sphere then attachj the back plate thing then i had to JAM then rotating part in (jam capitialized for good reason)
f8sjester
a broadway mirror wouldn't help anyway since all it does is snap onto the real mirror
