1WheelWonder »
https://forums.nicoclub.com/1wheelwonder-u24780.html
Tue Aug 22, 2006 1:39 pm
I am currently putting my built motor back together and went to check the specs on my shim to cam clearence ( according to Joel07 from Ka-t.org it should be .0138 cold on the intake side and .0148 cold on the exhaust side). I figured they would be all out of wack because I accidently flipped my head upside down scattering the order of the shims while taking it to the machine shop for work. Well when it came back I just through them back in there in no particular order and checked the specs, netting me 4 out of 16 within Joel07's specs. One of them is .004, two of them are .005, four of them are .006, three are .007, one .008, and one .010. My problem is that I really don't know what I need to do to bring them back to spec, I know shims are available for purchase but i'm not certain on how to go about selecting the right ones. I would assume I could subtract say .004 from .0148 and get .0108, which should be the shim size I need, would this be the correct way to do it, where could I get shims, and do they have all the sizes I need? I apologize if this question is worded incorrectly, this is boggling my mind. Any help will be appreciated.
