Simmsled »
https://forums.nicoclub.com/simmsled-u3103.html
Tue Jan 27, 2004 7:06 am
Use 8 awg for your power wire if you are running up to about 400 watts. If you are running more than that, use 4 awg. If you have a 1200 watt (RMS) sub amp like me, then it makes you use 4 awg for power wire and 8 awg for speaker cable. I've been using Streetwires 10 awg for my sub speaker cable and Streetwires 4 awg for my power cable for a long time. The 15 awg is strange. It is something you dont normally see. Usually the size rating is 14 or 16 awg. That cable is best used as speaker cable. If you are running more than 500 watts per sub, you should consider 14 awg or even 12 awg over 700 watts. REMEMBER, THOSE WATT RATINGS ARE (RMS) reliable RATINGS, NOT the (ISBL, If Struck By Lightning) max power rating. ISBL is just something that I made up to make fun of the amps that claim 1000 watts but then only have a 20 AMP fuse and barely put out 150 watts RMS. I hate that so much.
