Stupid S13 front bumper question
DawgMode
Car: 180sx
can someone give me a quick write up on how to take the front bumper off???
Zydeco
Car: The poster formerly know as -]sTm[-HeavyHips
here try and download the factory serice manaul, it tell you all you need to know.http://www.zeroyon.com/techfil...4.zip
naed240sx
Car: .....
I just looked around for bolts, took em all off, moved it untill i could figure out where the other bolts were. Wasnt too hard. There should be about 4-5 bolts holding the bumper to the fender right behind the vertical line where they meet(on both sides), a couple under the hood, holding it down into the frame, a couple from below... that should about do it. BTW, taking em off is hard, putting them back on is harder. I had to omit a few bolts on the reinstall, but its on there solid, so i dont care.
good luck
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
ah.. this will be fun for me as well, my recently obtained s13 coupe's front bumper is crooked under the driver's side headlight for some reason.
naed240sx
Car: .....
I had a similar problem i think. like there is a gap underneath the healight even when it is completely closed, because it contacts the bumper with its corner? I just sanded that little corner down a bit. Ur gonna have a hard time adjusting this by taking it off.
good luck though
DawgMode
Car: 180sx
thanx
skydragoness
naed240sx wrote:I had a similar problem i think. like there is a gap underneath the healight even when it is completely closed, because it contacts the bumper with its corner? I just sanded that little corner down a bit. Ur gonna have a hard time adjusting this by taking it off.
good luck though
No, it's more like the driver's side headlight hits the bumper when closed, its as if it needs to be tugged down slightly. I'll post a pic to better show the problem. It's one of those things that's not noticeable from far away, but when you walk up to it, it's quite obvious, and annoying. My first S13 was straight everywhere. This car had some baboons working on it.
jmwenick
Car: 1991 240sx Base Model
Mine is exactly the same, the headlight hits when closed, i'll fix it when I find a new fender.
skydragoness
Here's some pics of what i'm talking about:
It's annoying as hell. Can anyone think of a way that i might be able to undo *some* bolts/sections so i can tug it to where i want it?
Rusted_PS13
Car: 1991 Nissan 240SX
Man, that paint still looks new. Your gonna have a hard time adjusting your bumper to flush in with the headlights. I tried mine but it was a no go. Think adjusting the light will fix it?
naed240sx
Car: .....
I cant tell whether or not it is touching the bumper. If i is, you are probably out of luck. If not, adjusting the light so that it closes fully will work fine. If it is touching, you can still adjust the other light so that it will at least be even.
kouki-gymkhana
Car: 1993 Nissan 240SX (only 90,000 mi!)
The easiest thing to do is to adjust the headlight cover. There is some adjustment built into them so you can tweak it. As for the fender not lining up with the bumper....I think you're going to have to live with it.
BTW, I W-I-S-H my paint looked that good. (Damn these Philly drivers who believe that parallel parking is a contact sport!)
skydragoness
Well I bought it last month, it's a fresh maaco-style paint job, complete with paint *around* the mudflaps, red paint overflow on the fog light wiring, etc. But no rust, and new paint is better than old paint even if it is orangepeel-y up close.
It does have its share of quarter-sized dings on the passenger side, and a small dent on the driver's side door. As far as the front bumper goes, i'll be damned if i can't hit it with a rubber mallet *somewhere*
the back of the car is much more of an eyesore:
Modified by skydragoness at 12:35 AM 7/19/2005
