Stupid Qustion about Z32 Brakes Swap (Searched)....
Ali 556
Car: '95 S14 Se....
hi,
i have a qustion about the Z32 brakes swap on my S14..my car s a '95 S14 SE....
My qustion is :
Is the brakes ''DIRECT BOLT ON''....so if i take my front and rear rotor out..can i just but the Z32 rotor on with NO modifeing any thing on the car beside the brake lines and E-brake cabels...
b/c i found a good deal on Z32 brakes.the dudes is selling them for 290$ for all four's (Clipers+rotor's) WITH brake lines...
also Is this a good deal....?
Thanks'n'advance...
Ali
Hijacker
Car: '92 240sx Convertible
'94 F-150
If your SE is 5 lug, it should be a straight swap.
I suggest getting brake lines from SPL Parts. They're great quality lines, and they're affordable.
As with all projects, be ready for some weird problems to pop up. Like with mine, the rear e-brake fought me 100% through the install. The rear hubs wouldn't come out to let me swap the heatshield, and then the Z parts were being a pain to install.
Ali 556
Car: '95 S14 Se....
tenkawa_akito wrote:If your SE is 5 lug, it should be a straight swap.
yes me SE is 5 lug...i'll buy SS brake lines from SPL and E-brake cabels from thenismoshop.com they sell skyline R-33 cabels for 90$...
Thanks
Ali
nwmrkt
Car: S13
What ebrake cables are needed for a s13? z32 or r33? I heard z32 ones work fine?
S14-KOUKI-MONSTER
Car: '97.5 Kouki s14 le w/Kouki s14 sr & '03 Xterra w/6" lift on 33s
Make sure that the brake hoses have the hardline that connects the hoses to the caliper, or you'll have to make them like I did. You'll also have to trim the lip off the splash guard and bend it back a bit to avoid rubbing on the new rotor. A disc grinder will do the trick.I only have the fronts swapped, so I won't mention the rear since I'm not 100%. They were super easy to install though. Just make sure you get a few bottles of brake fluid though.
driftknight
now i have a questions, i have an s13 and if i was to swap the real then i would need replace the stock ebrake cable or can i use my stock cable
Ali 556
Car: '95 S14 Se....
driftknight wrote: now i have a questions, i have an s13 and if i was to swap the real then i would need replace the stock ebrake cable or can i use my stock cable
IIRC...if you replace the stock brake cabels it's lees headach....the R33 skyline will BOLT RIGHT UP <--this on S14's...i don't know about S13...sory
Ali
