stupid question
ShionS14
Car: 2003 Saab 9-3, 2005 Infiniti FX35
i was just wanting to know how exactly you go about taking out a stud in the head for the exhaust, i know it screws in but how do you actually get it to unscrew?
Dattebayo
Pray to the stud god for removal and make a human sacrifice to appease him.
250sx
get 2 bolts and tighten both bolts on the stud. actually, tighten both bolts against eachother. and then use that to take out the stud.
Dattebayo
And then use the bottom nut with a crescent wrench to remove.
Then make human sacrirfice to stud god for removal.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Or if you are like me, the studs on your fourth port just come off when you unscrew them and are bishez by resisting to go in, so you have to re tap it and screw it in..... >: / I have had the most damn trouble ever the my hotshot header...... Leaks, warp, clearance issues, lining up problems, gaskets gaskets gaskets and.... did i mention, MORE GASKETS?
ShionS14
thanks for the advise, greddy turbo kit requires that you remove an exhuast bolt and replace it with theres so i am just preparing
hbrown
If you aren't concerned about reusing it just grab it with vise grips and unscrew it- they aren't in there that tight- at least they weren't on mine. I had the same issues as above when I put on the hotshot header- except I had two studs just snap off in the head- I very carefully used a right angle attachment with a drill and drilled them and used an ease-out-they came right on out- I was prepared for the worst but it was Ok.Once I got some hardened studs and installed everything I haven't had anymore trouble.
