stupid question (no flammin pls)
farmer
Car: 1990 nissan 240sx
i was lookin on my rb26 for the serial # on the block to give to my friend to determine what series of motor ive got , but after a quick glace i didnt see the # , now i was looking in the same place as the sr20 motor but it doesnt appear to be there , so my question is where is the serial # for the rb 26 motor, cause i want to sell the transmission and front diff thanks in advance
farmer
themadscientist
driver's side, just above the oil pan rail and back by where it bolts to the transmission. There should be two machined surfaces with numbers stamped into them, lower should say "RB26" and the upper should be the number you are looking for. There is also a block casting code raised up on I think it's the turbo side center above the pan rail.
farmer
so far all i found is on the driver side of the block is two sets of raised numbers about 4 inches above the oil pan there is a raised number then is says nissan then there is another set of numbers, could this be it ?
Taylor_Durdan
you can also tell by the motor itself.
the R32 RB26DETT has black valve covers and front covers, uses a finned ignitor that sits flush with the center cover and uses the old style black plugs like the 300sx (the kind with the metal retainer clip)
the R33 Series 1 motors look pretty much the same, but use the newer 'push-button-to-release' clips on the ignitor and the ignitor attached onto the top of the center cover
the R33 Series 2 doesnt even have a visible ignitor. theres just two black plugs that join together where the ignitor used to be
farmer
im just concerned about the oil pump failure issue with r32 motors and i want to make sure i dont have the same problem. thnks
famrer
gawdzilla
Car: none
only way i know to make sure is to take off the oil pump. supposedly there is a stamp on the head (exhaust side, rear near the lift point) that will tell you, but mine didnt have it. some late r32s have the good collar. considering you're probably going to be doing the timing belt and water pump anyway, its only like 1 step deeper than that. i'd just pull it off to look.
