Urq wrote:There will be no added stress to your strut towers.
First, we're talking about the struts themselves, not the strut towers (which are part of the body).
Also, this is an incorrect statement if you apply it to the struts themselves. With a good set of lowering springs you can MINIMIZE the amount of extra stress, but you cannot ELIMINATE it entirely.
Your car's suspension is designed to work optimally when all parts are stock and properly adjusted. If you drop the car, you're changing dimensions of the suspension (shortening the average and maximum ride heights) and as such your "suspension geometry" is changed.
The two worst things you can do for your FACTORY struts is to either cut the springs, or use an extreme drop kit.
Ever wonder why the "top" spring manufacturers usually don't drop a car more than 3/4" to 1?
If you don't believe me, go log onto an Autocrosser's forum... ask about lowering with stock struts... and ignore those Honda boys, they don't know what they're talking about unless it's 2Fast 2Furious, yo. (besides, the Honda guys often think it's a good idea to cut stock springs. That should tell you a lot right there.)
Now, I wouldn't think twice about sticking lowering springs on a good set of KYB or Tokico struts... but they're not made yet.
