Stupid question about Radiator inst.
240tek
Car: 89 fastback
Sorry, for the noob questions. I gotta replace my radiator. I am gonna get a 300zx tt cap, I hear the higher bar is better. People told me to replace the thermostat too. Where is it located on the Radiator? Thanks. PEACE. Tek.
Axel Grungy
Car: 2001 G20 5spd
its not on the radiator. its located right where the upper radiator hose connects to your engine. HTH
C-Kwik
Just an FYI, a higher pressure cap doesn't do anything unless the coolant is actually boiling to some extent. Higher pressure caps just holds more pressure in the cooling system which raises the boiling temperature of the coolant. But the temperature is not really lowered by this. It becomes effective though when the engine gets so hot that coolant starts to boil. Boiling water introduces air into the cooling system and air is much less effective at carrying heat away from the motor than water. So if your system is not causing water to boil, you won't see any benefits from the higher pressure cap.
[s3]
C-Kwik wrote:Just an FYI, a higher pressure cap doesn't do anything unless the coolant is actually boiling to some extent. Higher pressure caps just holds more pressure in the cooling system which raises the boiling temperature of the coolant. But the temperature is not really lowered by this. It becomes effective though when the engine gets so hot that coolant starts to boil. Boiling water introduces air into the cooling system and air is much less effective at carrying heat away from the motor than water. So if your system is not causing water to boil, you won't see any benefits from the higher pressure cap.
But but but, guy at the rice store says it adds 20 mental HP.
240tek
Car: 89 fastback
Yeah I know that much. I figure it's the same price as the 240sx one, but higher bar, so it is an added level of security. PEACE. Tek.
navysnail
the higher pressure may cause damage to the system, which is designed for 14psi. id say stick with stock cap unless you drop in a koyo or something.
