Samurai C »
https://forums.nicoclub.com/samurai-c-u96697.html
Thu Jan 29, 2009 7:22 pm
you can get a kit from you local parts store
get a chain, gears, guides, tensioner, and oil pump (build into the lower cover) i have done chains on FWD KAs were i did the work and it still made noise cuz the oil pump was shot
now ive only done FWD KAs so far but the cover gaskets are just RTV but get the grey RTV it is Nissan approved. you will need a valve cover gasket and oil pan gasket (if it needs to be removed and if its not RTV, again ive only done FWD ones)
i warn you THIS IS NOT A SIMPLE REPAIR, you are doin major engine work.if your chain timing is off you will damage the motor
i have gone to take the cam gears off with a air gun, my helper lost the grip on the holding wrench on the cam, spun the cam and because the piston was at TDC it bent the valves. lock tight and torque everything. triple check your timing marks befor you install the chain. you cant test start till most of the motor is back together because of the oil pump.
good luck
if i am wrong anywere please feel free to correct me ive only done FWD KAs i have yet to take mine apart but i believe it is very close if not the same
