I use both. If I'm parking uphill I place it in a forward gear, and apply the parking brake. I don't think you'll wear out your emergency brake, because the car isn't in motion when the brake is applied. You will after frequent use need to retension the parking brakes. As time goes on, you'll notice that you have to pull the e-brake up farther to get the same amount of force, by tension it tightly you can get the same pull in just a couple of clicks.editguy29 wrote:I have always wondered how should you park a manual trans car? Neutral or first gear? My dad says first gear, but has no reason why. A friend of mine also said first gear and said it is becuase you will wear out you emergency brake. ?????
Also a good idea, I think the last time I heard/read that was in the booklet I got before I got my drivers permit I always make sure my wheels are pointed straight ahead. Again old habits are hard to break (4 years as a valet parker).samej82 wrote:I always turn the wheel into the curb too, so if i did roll or get bumped the car wouldn't end up down the street but stop at the curbing.
what?bone_stock_240 wrote:No damage will be done to the trans.
So, do you disagree with what I said or do you agree?bone_stock_240 wrote:Can someone explain to me how leaving it in gear and getting bumped will damage teh transmission?? Even if you get bumped significantly hard, and your wheels actually do spin, all that will happen is that your engine will turn a couple of times. Where is the massive drivetrain damage coming from? I would think if you get bumped that hard, a damaged transmission would be the least of your concerns.
http://www.audi-forums.com/8p-....html
http://www.whtc.com/Shared/Aut....htmlgo down to step 8
http://www.essortment.com/home...z.htmlook at step 4
http://www.10w40.com/individual/100186.aspgo down to "Watch your hands - the gearshift" section
Seriously, if you guys do not know what is going on, do not try and pass on your bad habits to other people. Even if you are parked on a perfectly flat surface, you should leave your car in gear. If you don't that is fine, and it probably nothing bad will come of it, but it isn't the right thing to do. Leaving your car in gear every single time you park the car will minimize you forgetting at a time when it would actually save your car.
I can't even imagine what kind of hit it would take to do that to an auto transmission. I remember when I took a tour of the ford assembly plant in Oakville, one of the first things they do when they roll the pickups off the line is slam it in park when they are doing 25 km/h.evildky wrote:getting bumped causes body damage not trans, actually there would be mroe danger to an auto trans in park sustaining damage, in theory you could break the parking pawl but that would take one heck of a hit and the wheels would have to be anchored to the ground
