Stupid map lights !!!! Help afraid of dark.........
topdowninaz
Car: 1994 Nissan 240sx SE
OK.... so I have searched everywhere for info on this and am coming across nothing for those little lights in the mirror of my '94 240.
They are not working, I replaced both bulbs. I replaced the fuse, at least the one I thought it was. Dome light works, dash lights work, ashtray light works but god knows why its there. So basically all interior lights work but the two on the under side of my mirror.
I bought this car recently and they had a stereo installed at Best Buy mes think. Maybe that has something to do with it.
Any advice or people having same problem?????
THANKS
NISTECH
The only place that info will be found is in the 94 240 convertable service manual supplement. The power to them is basically the same as hard top models with a sunroof. You need to trace the wires coming out of the mirror to their source, this means pulling down some trim at the top of the windsheild frame. the wires will likely run toward the drivers side and down the A-pilar. It will likely be easier to pull the A-pilar trim off first and see if you can locate the wire. compare those to the wire plugging into your mirror that should be in plain veiw behind the mirror. Once you have determined which wires they are in the piler trace them down to under the dash. and try to locate where they are at the fuse box.
