hearse83 wrote:So...after you press the lock button and it flashes, did you turn it off, take the keys out and unlock it
or did you unlock it, then turn it off, and take the keys out?
After i press the lock button and it flashes, I turn it to off pull key out press unlock
but it sounds like you did that and it didnt work..... it should be a fairly simple procedure and i really dont know whats happening!! Maybe the remote starter is interfering... remote start would have to bypass the infiniti transponder key security system... i dont see how that would have any effect on the remote but then again, i have no idea how the nissan keyfob/transponder key system works. I know how to program it, but i also took it apart once to see what it looks like and its nothing but electronics....
in fact, right now i have a problem where my remote will unlock the drivers door but not the rest. (but it will lock all of them) But i suspect it is due to some broken electronic components in the drivers side door, from a break-in attempt. Like i said, i tried to figure that system out and have no idea how it works
good luck dude !! sounds like you have a real annoying problem!!
