Stupid intercooler question
rudee023
Car: '03 Infiniti Q45
On aftermarket FMIC's where is the wastegate signal located? (Blitz, HKS, Greddy, etc...) Also, do all come with the large hose on the coldpipe to the IACV? Because in all the pics I see in advertisements the pipes rarely show any nipples coming off of them. I'm retarded I know.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
the wastegate signal comes from any pressurized area of the intake, not from the IC specifically. [hotpipe, coldpipe, nipple on the compressor itself, tee from another vacuum line, ect...]
no idea about the IACV line.
rudee023
So those running aftermarket IC's simply "T" off of one of the vacuum lines on the throttle body and run that to the wastegate? I am already "T"ing off of the FPR line for my boost gauge.
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
On my hotpipe, there is a nipple that I used for my wastegate.
Big Perm
I have the same issue. My Greddy VSPL & Enjuku Hot Pipe kit lacks a nipple on that side for the wastegate.
So if I "T" off the line that goes to the BOV, will that work?
Also
I am using the JDM air intake tube. I have one mystery vacuum home coming off of it that I have no idea where it goes to.
Any help?
robbbby
Any help?
To recirculate the air released through the BOV I would think.
Big Perm
I don;t think so, there is a larger one on the other side for that - this is the size of a small vacuum hose
robbbby
To connect the outlet side of a catch tank to the intake then?
VitaminT
Car: 93 240sx SE
The older model Greddy VSPL dosen't have any nipples. The Heavy Throttle hotpipe does though.
Big Perm
Big PermIntake/Exhaust
Registered: Jun 2003Location: Roanoke, VAPosts: 98Car: 1993 Nissan 240sx Coupe I have the same issue. My Greddy VSPL & Enjuku Hot Pipe kit lacks a nipple on that side for the wastegate.
Also
Any help????????????????????????????????????????
__________________
180crafter
Car: Nissan 240sx
I use the T method. Works like a charm.
In all honesty, I would use this way anyways. When you take the signal from the hot-pipe, its not really the correct boost the engine sees. Boost builds earlier in the hotpipe, and also, hot air expands more then the colder air on the "cool" side of the intercooler.
I think this would be less of an issue with the stock WG, but for boost controllers or aftermarket wastegates, I would use the T method (with lines as short as possible).
Hijacker
Car: '92 240sx Convertible
'94 F-150
my FPR is Teed for both the boost gauge and the wastegate. Aaron, if you want see how mine is done, give me a call 309-9586
Big Perm
I think I got it done. Almost done man, just gotta get the timing right this week and it will be ready to run. I'll give you a shout on Monday or Tuesday. I won't be able to work on it until possibly Tuesday after work. I'll give you a shout and maybe we can get together and look over what I have done.
Big Perm
BTW WHAT IN THE HELL IS UP WITH THIS FORUM TODAY? Been acting funny now that it is finally back up
