Stupid healights.. yes, flip up problems..
Two Fowty
Car: 1990 240sx hatch, 1989 240sx hatch
Just got new flips ups (used) + motors (used). My old ones didn't work, or so I thought.
Hooked them up, long story short, the lights only flip up when I turn on highbeams, or push the button in the dash. They don't go down at all unless I manually turn them with the nob on the motor. Also, the passenger side light only flips up half way, whereas the driver side flips up all the way.
I read some threads on here about the lights not going down, and only working with highbeams and the button, so I'm sure I can fix that. The main problem I'm lookin at is the passenger light going up only halfway, any ideas?
adrianfromthecastle
Car: 1992 Nissan 240sx
possibly a bad headlight switch?
I used to have a bad headlight switch... it caused only one of my headlights to pop up and only one light would turn on...
you sure all the connectors are secured/ grounded?
Two Fowty
are you referring to the little button in the dash, next to the steering collumn kinda?
and the grounds for the motors are secure and good
adrianfromthecastle
I'm referring to the actual combination switch itself.
cacaface
Car: 240sx 93' Conv with manual sr20
did you happen to check out this?zerothread?id=280461I had a different problem, but this sounds like it might fix yours also... maybe.
24j0hn
Car: 91' 240sx with some babying to be given
did you check the fuse?, but it mostlikely could be the switch
Two Fowty
hmmm... ill check that out then
Two Fowty
yea i tried to do the cleaning thing in that link, and i couldnt even get the white piece out to even do anything, so i quit and put it back together, and now my high beams and turn signals dont work. fml. these cars are annoying
