stupid headlight! pleeeaase help
nice_try
Car: '90 240sx with a bone stock sr20 swap!
ok. so my headlight won't come up without a little persuasioni turn on my lights and only my driver side comes up.my passenger side lights up. it comes up if you twist the knob a little.i'm not talking manually twist it all the way. you twist it a small bit and its like the motor just kicks in and the headlight pops up
i need help for sure guys
onosqv
Car: '92 240sx Vert
new headlight motors/assembly. problem solved (most likely from the way you are describing).
