PMan_S13 »
https://forums.nicoclub.com/pman-s13-u3715.html
Sun Mar 06, 2005 3:11 am
I would seriously consider looking at the alternator again, if it were me.
Very similar thing happened on a friends accord with subs/amp. The stereo drew so much power it exhausted the alternator.
If you're mecahnically inclinded, it only takes maybe a half hour to take the alternator completely off the motor. If you take it to autozone, advance auto, napa, etc. they can do a detailed diagnosis on its performance. It's a little more clear than the old voltometer =)
BTW, if the car is running, there HAS to be a voltage across the battery, otherwise you can't spark, use fuel injection, use timing, tach, speedo, etc. You can have a bad alternator with a running vehicle... it just means it doesn't recharge as much as the car is using.. so it will drain the battery and then be dead.
Hope that helps somewhat.. good luck
