Atta boy Smockey. You make Canada proud...smockers83 wrote:... The guy next to me asked if I couldn't find the hole as I aimlessly poked the dipstick around and I explained to him that it's way down in there and one of the worst locations...
Park your vehicle on level ground. Best time to check your oil is prior to starting your engine in the morning. Otherwise let the vehicle sit for 20 minutes or more so that all the oil from the engine including the dipstick tube drains back into the oil pan. Yes it a pain designed that but its still a great vehicle. BTW the L mark is two quarts lowcsguy0 wrote:No pun intended... I just recently switched to Shell Full synthetic motor oil and I am trying to make sure that they didnt overfill it... Everytime I take the dipstick out to check it... the entire dipstick is covered in oil... even after wiping it. This is whether it's cold or hot. Is there a trick to our dipstick?
Thanks,
David
You know I think my old Lexus had one? I can't quite remember?Gee that could be my first mod for my G?A bright low wattage environmentally safe bulb wired in series thru a mecury switch to 12v battery and groundJacko3 wrote:A little bulb under the hood would have been helpful from Infiniti. Anyway, the car was designed in the day time. I doubt the engineers did any type of design and testing at night.
Keeping costs downJacko3 wrote:Telcoman:
You are right. Even cars in the 70s had small bulbs under their hood. An inexpensive and small LED light would be adequate as it uses less current than a regular bulb. Why is the simplest stuff so hard for the auto manufacturers?
That was one of my first mods on my I30. I went to autozone or kragen and bought 3 LED that came with a switch, I drilled the holes for the led holders (just slightly larger than the LEDs) and ran wires through the hood skeleton. I was sooooo happy to find that the switch diameter was exactly the diameter of one of the holes in the hood.telcoman wrote:
Hey man, I do what I gotta do.rn79870 wrote:Atta boy Smockey. You make Canada proud...
