happy934 wrote:okay so I got a 92 hatch a couple weeks ago and have been doing work since day one. Now after installing coilovers, getting the dif welded, and other small things like that it has came down to my stupid dash lights not working. I checked the fuses but nothing they are all good. I took the dimmer switch out of my boyfriends 240 but still nothing. Any idea what it could be? Sorry im new to the forms and just joined for this reason of help, so thanks guys!
-Nikki
I'm willing to bet, when you put on the coilovers. You slammed the car.Most likely, you burned thru a wire or two on your harness. It runs over the drivers side wheel, and should be under the fender liner. If you dont have a liner, check your harness there. Good luck
