stupid crank pulley
Uncle Dat
Car: 96 240sx, 78 280Z
I searched and read about replacing your front main seal. I got everything until unbolting the crank pulley bolt. I put it in 5th gear with handbrake on and the sucker moved every time I rotated it. It moved in all gear. Any tip?
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Have someone press on the brakes and you should have some better luck.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
put it in 1st gear man..works like a charm
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Ever think of a strap wrench? I have one that holds up to me torquing the crank pulley to 110 ft lbs. It has been great multiple times. You need a special one though with a high tensile strength. I got mine at a local auto parts store.
Uncle Dat
I tried all gears...I might look into stepping on the brake and strap wrench. Honestly I never heard of that tool but will look into it OM3GA.
