Click to enlarge.
you can get exempt? crazy had no ideaiitywygms wrote:Join the crowd.
I have changed the cat, egr, ecu, bptv, o2 sensor, maf, and my results are still similar to yours.
I go to ref soon for an exemption.
Wish I could be more help. good luck.
The injectors are fine!JayArr wrote:I'm assuming that it's that 68ppm of HC that failed you correct?
Have you checked your injectors to see if any are leaking or dripping or not firing the fuel out in a fine mist?
JayArr
You can get exempt? How?iitywygms wrote:Join the crowd.
The EGR tube is brand new from nissan and does not need to be cleaned, i just bought it. Also the O2 is new as well. MAF is cleaned..i guess ill try the injector cleaner.LoserCard wrote:Ok so you have a working EGR valve. What about the piping that goes from the header to the EGR. Give that a good cleaning. I read online that lean fuel mixtures create hotter combustion levels = high NOx so check o2 sensor, clean maf, run some Lucas fuel injector cleaner. Do whatever.
Oh yeah my smogging guy (I regularly smog all of renewed/purchased cars through him) told me that the cheap smog places will intentionally run your car at less than optimum running levels, however still in correct testing range, to get a normally passable car higher emissions.
You can get an exemption and get the tags once. But next time it is do for a smog, it must pass or no tags.motoman399 wrote:you can get exempt? crazy had no ideaiitywygms wrote:Join the crowd.
I dont know about the BPT Valve or solenoid, but I took it to a shop and they said all emissions were fine but the catalytic converter(which i replaced). This was a while ago.Wc240 wrote:what about the bpt valve and egr solenoid?
how goods the motor, carbon build up will give high nox. at the 15, with your hc,nox, and o2 levels, you could be lookin at a small miss.
fuel soaked crankcase will also give high hc's.
what about the cooling system? your car is running very hot.
Tried it.LoserCard wrote:Denatured alcohol trick?
How long has it been since you rebuilt the motor? Until it is broken in, it probably won't pass. It'll run rich as hell.StryfeS13 wrote:The motor has new pistons, new rings, new headgasket, new cylinder head, new gaskets.
To be effective, you need to add 1 gallon of alcohol / 15 gallons of fuel.StryfeS13 wrote:Tried it.LoserCard wrote:Denatured alcohol trick?
Yep, I do. I drive it on the freeway for about 12 miles, turn around, floor it up the on ramp, downshift on the freeway from 5th to 3rd and floor it to like 80 lol...etc..you get the point, i run it.LoserCard wrote:You do run the car heavily before you smog, right? What kind of spark plugs you got in there?
It can be totally random and depending on the how long your cars been running until the test. I had a pretest that measured 773 NOx at 15mph, then during the real test the next day it read 1225. This was at the same smog shop.StryfeS13 wrote:The injectors are fine!JayArr wrote:I'm assuming that it's that 68ppm of HC that failed you correct?
JayArr
You know what's funny, is that my car ALMOST passed (it was like 100 NO too high) when it had a collapsing egr vacuum hose and a bad cat. Maybe this smog shop just sucks? They did my tests in 2nd gear, when I was under the impression it's supposed to be 1st gear @ 2.7k RPM for the 15MPH, and 2nd gear @ 2.7k RPM for the 25MPH.
