float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue Oct 20, 2009 5:57 pm
Yea, that peak you're seeing is the pressure wave building up before the BOV opens. It's not really too big of a deal actually, but you might soften it up a little.
As for the vac lines, you've got them routed a bit squirly. IDEALLY, the line for the wastegate is as short as possible. It doesn't need to see vac, so most ppl either tap the hot pipe or the compressor housing with a barbed fitting.
The BOV should be routed to the intake manifold. I use the tube right behind the throttle body on the outside of the manifold. Kind of under the throttle cable. You can also T it into the FPR line.
