SinceByMan »
https://forums.nicoclub.com/sincebyman-u7337.html
Sun May 16, 2004 11:37 am
is the belt on?
the same thing happened to me about a month ago, the bolt came out and my belt snapped because the alternator was crooked.
I would recommend you take the alternator belt off if it isnt already. Then you should be able to move it around a lot more. Did the bolt come out completely? You might want to check the threads of the bolt, mine were completely worn and I had to replace the bolt, also, theres a really funky nut that holds the bolt in place, it has a big rectangular piece of metal welded to it, you might have to replace that to, or use a regular nut but the funky one would probably keep it from happening again.
Hope I could help.
