Tharin »
https://forums.nicoclub.com/tharin-u26362.html
Sat Feb 26, 2005 7:06 pm
Hey all, I just convinced my girlfriend to pick up a '91 240sx SE Super Hicas to compliment my '84 300zx Turbo and it's got a slight stumble on acceleration. It's not too big of a deal but I'd really like to get it fixed. I noticed today that the stumble is also accomanied by a slight power lag and a chirping noise for as long as you hold the accelerator steady. The chirping noise is only noticable with the windows down and no stereo so I didn't pick up on it right away.
The previous owner was baffled by the problem and proceeded to replace all the usuals. The car has a new MAF, O2 Sensor, Plugs, Wires, Fuel Filter, and probably a few other parts. I, on the other hand, don't like to buy anything unless I'm pretty sure it's the problem.
I started out by cleaning the AIV valve, which was amazingly clean like most everything else in the car. This had no effect on the problem so I decided to pull codes even though there was no MIL light on. I pulled a VSS code (the speedo works intermittently but I don't think it's related... but maybe it is) and a Knock Sensor code. I erased the codes and let the car warm up and then proceeded to test the RPMS. You could feel the stumble occasionally in idle up through 4000 RPMS. It might occur above that as well but it's late and the neighbors don't like "hotrodding" around here. It feels like it could be a miss but it's very subtle. I pulled the codes again and got a CAS code.
I'll be checking all the connections on the various sensors and getting voltage readings off the ecu tomorrow but I was wondering if there's anything else I should look at. I'll probably pull the timing cover off and remove the guide while I'm at it. Anything else? Thanks.
Tharin
EDIT: Forgot to note... the problem only occurs after the car has warmed up.
