Stumbling before warm up?
damesta
My CA boggs, stumbles and runs like total crap until it warms up. Its not really that big a deal, just let it warm up for 2-3 minutes and it runs perfect. I know CA's are known for being difficult when they are cold but is it usually this bad? I can't seem to find whats causing it, no codes, no other problems at all, A/F ratio tests in mode 1 and 2 check out, etc.
Trigger
you do have your line coming from your air regulator hooked up to your intake right....that was my problem as soon as i hooked that up i had no problem what so ever
Tim
damesta
Yeah, air regulator is hooked up, it idles fine before warm up, its just the stumble that I'm curious about.
boost_boy
damesta wrote:My CA boggs, stumbles and runs like total crap until it warms up. Its not really that big a deal, just let it warm up for 2-3 minutes and it runs perfect. I know CA's are known for being difficult when they are cold but is it usually this bad? I can't seem to find whats causing it, no codes, no other problems at all, A/F ratio tests in mode 1 and 2 check out, etc.
You have a faulty AIV. It's the grayish-colored funny looking piece a tad bit below the T-body. They do go bad and cause the symptoms you complain of.
Dee
damesta
OK, I guess it is the air regulator then, anyone have a good one for sale?
boost_boy
damesta wrote:OK, I guess it is the air regulator then, anyone have a good one for sale?
You got mail!
Dee
capowered240
Car: 90 240sx
I've got one if you still need one.
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
How much? I might need one too.
damesta
Hey capowered240, email me a price, [email protected]
UMS_CA18DET
I have a Air Regulator willing to let go for $15 shipped.
damesta
Does it work?
UMS_CA18DET
yup, removed it because I didnt need it since I was only using 1 idle valve to control my idle.
boost_boy
I caution all of you, don't be uttering worthless parts. You all better make sure you test that thing and test it the way it is supposed to be tested because it is a sensitive part that fails for no apparent reason. Even if he is paying pennies on the dollar, make sure it works because I'd hate to emailing one of you for selling garbage parts.
Dee
capowered240
Car: 90 240sx
I also have a ficd solenoid valve if anybody needs one.
Modified by capowered240 at 6:43 AM 6/26/2006
DjLiquid
Car: 1988 Nissan Pulsar
Its funny to me because my car stumbles, stutters, and has one hell of a time trying to start up. The exact same symptoms you listed but when my FICD or AIV sensors become unplugged, the car will either stop running or run even crappier
boost_boy
DjLiquid wrote:Its funny to me because my car stumbles, stutters, and has one hell of a time trying to start up. The exact same symptoms you listed but when my FICD or AIV sensors become unplugged, the car will either stop running or run even crappier
It does this because the bi-metal plate gets stuck 1/4 or 1/2 open which is the reason why it stumbles and act stupid. And when you unplug it, you gets nothing but a stalled engine.
Dee
nnkfws333
Hey Dee email me at [email protected] for a quote on the air regulator. Thanks!
boost_boy
nnkfws333 wrote:Hey Dee email me at [email protected] for a quote on the air regulator. Thanks!
You got mail!
Dee
rico05
Car: 1992 RMS13 w/ CA18DET
NOT RIPPING ON DEE, but I bought a used one from him (good price too) and no change. You can use one from a B13 SE-R and they are about $92 + tax and shipping from the dealer. I will be buying a new one as soon as my new debit card arrives in the mail.
