boost creep »
https://forums.nicoclub.com/boost-creep-u234031.html
Tue Apr 29, 2014 12:26 pm
my 90 n/a manual has a stumble or hesitation from idle to 2500-3000rpms. it does it 75% of the time and playing with the gas pedal ever so slightly can make it go away till the next time I down shift or up shift.
however if its cool out and I only let it warm up for a few mins and drive the car before its to normal operating temp. the car drives great, fantastic even! but once its warmed the stumble or hesitation sets in.
i ran my codes and it gave me a code 34 det sensor, im assuming its a bad connector or nasty terminals in the connector.
can I have everyones input on the det sensor issue. where it exactly is/how to deal with it, weather its most likely the culprit, if I should relocate it (as im an n/a I assume it wouldn't be a huge issue)
