codes
P0307 say 7 missfire - but its not a constant miss - comes and goes
sometimes get knock sensor 0325. (Nova ODB2 reader)
had a miss on 3 but found a rat chewed wire to injector and repaired that
checked or replaced --------
camshaft sensor ( driver bank) opened - clean just like brand new)
fuel pressure good per FSM (fuel pump and control module are two years old)
injector cleaner run through tank and engine with 91 octane
Fuel filter replaced
new spark plugs
MAF cleaned - does normal fail mode and recovery when disconnected at idle
IACC operating - good cold start, then starts to miss at idle when warm
found broken intake boot emissions fitings between MAF and throttle body REPLACED large boot
and all attached hoses and clamps
found broken "Y" hose below IACC down to lower pipes at top rear of engine(damn hard to reach) REPLACED "Y" hose. Idle speed adjuster effective
replaced small vac hose driver side fuel rail regulator/damper to manifold
all coil packs will flash my timing light when looped over coil lead in head or in the "wire loop" dvr side
Need some ideas and HELP -- THXXXXXXXXXXXXXXXXXXXXX
