InjectedPerformance »
https://forums.nicoclub.com/injectedperformance-u22434.html
Wed Mar 01, 2006 7:41 am
Guy's we have some items that have been sitting on the shelf to long. If you see anything you like e-mail us or I can e-mail you! These items will be blowout pricing.
ACT- Nissan SR20DET 14.1lb Flywheel
AEM-30-1601 EMS 1989-94 JDM SR20DET Swap
APEXIAPX 403-A053 E.L. II Gauge Meter Control UnitAPX 403-A954 E.L. II Gauge Boost Kpa BlackAPX 403-A955 E.L. II Gauge Boost Kpa WhiteAPX 403-A956 E.L. II Gauge Oil Temp BlackAPX 403-A957 E.L. II Gauge Oil Temp WhiteAPX 403-A958 E.L. II Gauge Water Temp BlackAPX 403-A959 E.L. II Gauge Water Temp WhiteAPX 403-A960 E.L. II Gauge EGT BlackAPX 403-A961 E.L. II Gauge EGT WhiteAPX 403-A962 E.L. II Gauge Oil Pressure BlackAPX 403-A963 E.L. II Gauge Oil Pressure WhiteAPX 403-A964 E.L. II Gauge Fuel Pressure BlackAPX 403-A965 E.L. II Gauge Fuel Pressure White
ARP-ARP 102-4701 Nissan SR20DET Head Stud Kit
BLITZBLI 15058 Dual Spec Boost Controller Spec S Single SolenoidBLI 19280 Gauge Link - DC Live Unit 2BLI 19281 Gauge - DC2 Boost Meter 2.0 Bar (Carbon)BLI 19282 Gauge - DC2 Boost Meter 2.0 Bar (White)BLI 19284 Gauge - DC2 Temp. Meter Oil/Water (Carbon)BLI 19285 Gauge - DC2 Temp. Meter Oil/Water (White)BLI 19287 Gauge - DC2 Pressure Meter Oil/Water (Carbon)BLI 19288 Gauge - DC2 Pressure Meter Oil/Water (White)BLI 19322 Gauge BLM Temperature Oil/Water Carbon Face Black LightBLI 19323 Gauge BLM Pressure Oil/Fuel Carbon Face Black LightBLI 19324 Gauge BLM EX. Temp EGT Carbon Face Black LightBLI 19444 Gauge - DC2 Exhaust Temp./Rpm (Carbon)BLI 19445 Gauge - DC2 Exhaust Temp./Rpm (White)
BRIDEBRI F33AMF Exas III (Black)BRI N045FG 1988> Nissan 240sx Seat Rail Right Full Bucket
CUSCOCUS 222-261-C Roll Cage 4 Point S14 (No Sunroof)CUS 222-474-L Adjustable Upper Arm, Rear, S14, 240sxCUS 222-495-A Pillar Side Bar, S14, 240sxCUS LSD-162-L15 LSD Type RS 1.5, S13 & S14, 240sx
DC SPORTTSDC NTM4203B 1989-95 Nissan 240sx SR20DET S13 Only Turbo Manifold
DEFIDF 01905 2 1/16" Defi-Link Boost WhiteDF 01906 2 1/16" Defi-Link Boost BlackDF 02004 2 1/16" Defi-Link (US Ver) Oil Press BlackDF 02005 2 1/16" Defi-Link Oil Pressure WhiteDF 02205 2 1/16" Defi-Link Oil Temp WhiteDF 02304 2 1/16" Defi-Link (US Ver) Water Temp BlackDF 02305 2 1/16" Defi-Link Water Temp WhiteDF 02306 2 1/16" Defi-Link Water Temp BlackDF 02403 2 1/16" Defi-Link (US Ver) Exhaust Temp WhiteDF 02405 2 1/16" Defi-Link Exhaust Temp WhiteDF 02406 2 1/16" Defi-Link Exhaust Temp BlackDF 03206 VSD BasisDF 03704 2 1/16" Defi-Gauge Oil Pressure (Black) DF 03903 2 1/16" Defi-Gauge Temp (White)DF 03904 2 1/16" Defi-Gauge Temp (Black)DF 04003 2 1/16" Defi-Gauge Exhaust Temp (White)DF 04103 2 1/16" Defi Gauge A/F Ratio WhiteDF 04104 2 1/16" Defi Gauge A/F Ratio BlackDF 04402 2 3/8" BF Series Defi-Link Oil Pressure AmberDF 04404 2 3/8" BF Series Defi-Link Oil Pressure Amber ImperialDF 04501 2 3/8" BF Series Defi-Link Fuel PressureDF 04502 2 3/8" BF Series Defi-Link Fuel Pressure AmberDF 04601 2 3/8" BF Series Defi-Link Oil TempDF 04702 2 3/8" BF Series Defi-Link Water Temp AmberDF 04704 2 3/8" BF Series Defi-Link Water Temp Amber ImperialDF 04801 2 3/8" BF Series Defi-Link Exhaust TempDF 05101 Defi-Link DisplayDF 05301 Defi-Link Fitting Kit - Fits 2 1/16" 2 3/8" and (3) 1/8" gaugesDF PDF00713SS Oil Pressure Sensor SetDF PDF00908SS Oil Temp Sensor Set
GREDDYGRE 10129010 Nissan PS13 / S14 / S15 / RPS13 MX DownpipeGRE 11920100 PS13/S14/S15/RPS13 70mm Turbine Outlet ElbowGRE 12020022 Nissan S14 Intercooler KitGRE 12020036 Nissan S13 Intercooler KitGRE 13522301 Nissan S14/S15 SR20DET Full Intake ManifoldGRE 16000801 60mm Boost Gauge with Peak Hold & Warning, WhiteGRE 16000802 60mm Electronic Boost Gauge w/ Peak Hold and Warning - BlackGRE 16000803 60mm Electronic EGT Gauge w/ Peak hold and Warning - WhiteGRE 16000805 60mm Electronic Oil Pressure Gauge w/ Peak Hold and Warning - WhiteGRE 16000806 60mm Electronic Oil Pressure Gauge w/ Peak Hold and Warning - BlackGRE 16000807 60mm Temperature w/ Peak Hold and Warning - WhiteGRE 16000809 60mm Electronic Fuel Pressure Gauge w/ Peak Hold and Warning - WhiteGRE 16000810 60mm Electronic Fuel Pressure Gauge w/ Peak Hold and Warning - BlackGRE 16000812 60mm Air Fuel Ratio BlkGRE 16001001 52mm Electronic Boost Gauge - WhiteGRE 16001003 52mm Electronic EGT Gauge - WhiteGRE 16001004 52mm Electronic EGT Gauge - BlackGRE 16001201 60mm Electronic Boost Gauge - WhiteGRE 16001202 60mm Electronic Boost Gauge - BlackGRE 16001203 60mm Electronic EGT Gauge - WhiteGRE 16001204 60mm Electronic EGT Gauge - BlackGRE 16001205 60mm Electronic Oil Pressure Gauge - WhiteGRE 16001206 60mm Electronic Oil Pressure Gauge - BlackGRE 16001209 60mm Electronic Fuel Pressure Gauge - WhiteGRE 16001210 60mm Electronic Fuel Pressure Gauge - Black
INVIDIAINV HS88NS3GTP 1988-91 Nissan S13 N1 ExhaustINV HS94NS4GTP 1994-99 Nissan S14 N1 Exhaust
NRGNRG SRK-100R NRG Quick Release Kit - Silver/Red
NXNX 20923-10 Import EFI Kit with 10lb bottle
ROTORAROT 168.42040.01 Nissan 240sx Front Left Slotted Rotor (4 Lug)ROT 168.42040.02 Nissan 240sx Front Right Slotted Rotor (4 Lug)ROT 168.42042.01 Nissan 240sx Rear Left Slotted Rotor (4 Lug)ROT 168.42042.02 Nissan 240sx Rear Right Slotted Rotor (4 Lug)ROT RO.42058 1989-98 Nissan 240sx Front Stainless Steel Brake LinesROT RO.48010 1989-98 Nissan 240sx Rear Stainless Steel Brake Lines
RPS TURBO CLUTCHRPS MS-17538-ST Silvia SR20DET Max 2400lb, Torque 475, Pressure 80%
TANABETAN DB1170 S13/S14 Sustec Transmission BushingTAN DC0011 S14 Sustec Pillow Camber ArmTAN DC0070 S13 Sustec Pillow Camber ArmTAN DL1170 S13/S14 Sustec Rear Pillow Upper LinkTAN DR0011 S14 Sustec Pillow Toe RodTAN DR0070 S13 Sustec Pillow Toe RodTAN DT0070 S13 Sustec Pillow Tension Rod
Modified by Marty T at 10:37 AM 3/17/2006
Modified by Marty T at 11:56 AM 7/7/2006
