StarPD »
https://forums.nicoclub.com/starpd-u54244.html
Sun Mar 18, 2007 12:43 pm
*18" x 8" -40 wheels and 245/45ZR18 100w tires will fit perfectly on F50.*2005 Q45 has automatic headlamp leveling. Earlier F50 has manual adjustment for headlamp leveling*F50 headlamp adjustment is easy, but bulb replacement involves removal of body components.*2005 Q45 has remote power trunk opening with key fob standard.*Horn honk on setting alarm with key fob can be disabled so only flashing of marker lights confirms setting.*Climate control has an "Econ" setting that reduces A/C comressor load, but to shut the compressor off completely requires hitting the #6 dash button TWICE while in Climate Control window.*Rain sensing wipers are standard on 2005, earlier may be an option on base models.*Auto headlight control may turn lights on and off too frequently, shortening the life of the very expensive HID low beams. Replacement requires additional $130 per side labor. These lamps may not be covered under warranty.*TPS indicators take a few blocks to provide readings.*Voice Activation Control is too cool. :-)*Side mirror tilt -down in reverse requires the mirror control switch to be turned to the side tilt is desired on for it to work.*Ignition timing cannot be easily adjusted. One member here states that it can be done with a CONSULT II, but I'm unable to confirm that (yet).*On steep downgrades, the cruise control applies the brakes momentarily and repeatedly to maintain set speed, resulting in bucking.*F50s corner flatter than non-active G50s, and have shorter turning circles, but have less steering feedback and effort. The speed-sensitive steering is electronic, and increases effort with speed rather than increasing ratios as BMWs do. Between that and VDC, F50s have more understeer than G50s.*Turning the VDC off and setting the semi-active dampers to "Sport" reduces understeer on fast curves.*There is a brighter high beam lamp available called a "9011" or "H1R1". See my spearate post on this.*F50s have a FSTB standard.*F50s have no thicker rear sway bars available.*Previous destinations cannot be deleted from the Nav system.*Climate Control window must be selected to display ambient temperature.*Climate Control settings can be displayed in split screen momentarily by turning the temp control while in other windows (but ambient temp doesn't show).*Trip mileage in Trip Computer does not agree with dashboard trip odometer display.*Fuel mileage reading is not accurate. Mine is off by 1.2 to 1.5 mpg.*Nav and audio settings require a lot of memorizing. They are quite involved. Keep your owners' and Nav manuals in the console.*There IS a dead pedal in F50s. It's just too close to the floor to do much good.
Anyone else?
