DaSerb,DaSerb wrote:I always wondered about the same thing.
I think 320kbps will be sufficient for DVD. FLAC's are much bigger files but you are right, they do sound flawless.
I'm not sure about Nero, but Ashampoo burning studio has two different options for burning MP3 DVD that can be played on DVD players capable of playing mp3's, or burn just a regular DVD with bunch of files that can be played only on PC.
Great job doing this.
You are my HERO!!!TXT wrote: get outstanding sound through the DVD player with existing .mp3 files you already own.
Thats exactly right and I knew this along but didn't actually think about it this method until it just randomly clicked one night. Yes, the M's sound processor does give what seems to be more power to the speakers at is using the Dolby processor. The reason for doing all those steps I mentioned is to turn the .Mp3 file I already own and turn them into .VOB and .TS files which is what a DVD player is reading.wingFeather wrote:You are my HERO!!!TXT wrote: get outstanding sound through the DVD player with existing .mp3 files you already own.
Logically, this shouldn't happen, as the source file was still compressed even though it was turned into something else. Perhaps the M's sound processor gives preferential treatment to 5.1 audio sources? Perhaps it only applies x watts per channel, so if you have a two channel signal, it is only (x) watts time two... but with a six channel signal, it applies (x) watts time six???
PS - I never realized how much of an audiophile I am until I begged my ex girlfriend to listen to some dvd audio in my M. She was unimpressed with the difference between the dvd audio, and her aux input of Pandora. To her, the song was more important than the quality. Either that, or she really is a cold-hearted b****
Nero 12's "Nero Vision" is now called Nero Video, so you will use that to create the Dolby Digital 5.1 DVD Disc. It took me a little bit of playing around with the application to get it to create correctly, but the end result is better sounding music. However, I'll list a few pros and cons:mr_luv wrote:I have been trying and failed at this since you posted. I have Nero 12 and it doesnt seem to have nero vision any suggestions or idea to perform this on Nero 12?
All true above but I have found a way to go through the set up process of making the DVD quicker. After I add all my songs, I can press a button that skips between different audio files, thats when I right click on a certain area and create my chapter.moedawg140 wrote:Nero 12's "Nero Vision" is now called Nero Video, so you will use that to create the Dolby Digital 5.1 DVD Disc. It took me a little bit of playing around with the application to get it to create correctly, but the end result is better sounding music. However, I'll list a few pros and cons:mr_luv wrote:I have been trying and failed at this since you posted. I have Nero 12 and it doesnt seem to have nero vision any suggestions or idea to perform this on Nero 12?
Pros: (1) The music is rendered in full Dolby Digital 5.1 sound, has crisp, clear sound and it seems to even make the sound of my Alpine Type X sub fuller.
(2) You'll be using the DVD drive so you have an extra 'slot' to use for music.
Cons: (1) The DVD Disc is created based on time, not by data, meaning, using this method to create music takes you back to the olden days of being able to only add ~17-20 songs for your cd to be used in your cd player that did not have .mp3 data reading capabilities.
(2) You are not able to see the song title data, or length of each song because each chapter 'runs on' the time, i.e. the start of Chapter 5 may be 20:12 instead of starting at 0:00 for that particular song.
(3) Creating each chapter is a slow process. You have to find out the exact point to create the next chapter by playing back the music and then marking it as each song ends, using a print-screened picture of the songs you added that has the times for each start and end.
If you want the best sounding music possible, creating the DVD Disc is the way to go. I'll be making CDs from now on though because creating a CD is a whole lot faster and easier than creating a DVD Disc. I can play over 10 times the amount of songs, see the titles, elapsed time for each song and...burning the 320kb .mp3s onto a CD does not sound that much different than the DVD Disc in the end.
I actually downloaded Nero 12 but it was in a format that Im not used to using so I downloaded Nero 10. Reviews say Nero 10 is better due to better stability and not having bugs and such that are found in Nero 12.mr_luv wrote:I have been trying and failed at this since you posted. I have Nero 12 and it doesnt seem to have nero vision any suggestions or idea to perform this on Nero 12?
No luck with Ashampoo and adding mp3's to data DVD. I did burn the data DVD (DVD-R) but car would not even read the disc.TXT wrote:DaSerb,DaSerb wrote:I always wondered about the same thing.
Are you saying our DVD players can play Mp3 files as long as a dump those MP3 files onto a DVD as a data disc? I didnt know it was capable of doing that. I'll try it and see. If so, then this may be easier and quicker but the sound output not being 5.1 dolby and instead the 2 channel stereo might sacrifice the full use of our car's sound system. I'll see if it makes a difference!
