Studdering RB20det
240+civic=pimp
Car: s13/rb20det, 2002 WRX, 1994 Yamaha fzr600
Need some advise.
THe car idles good but when you give it throttle it studders.
If you give it full throttle it pops and then stalls and then it will boost and go??????
Fuel pressure???
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
240+civic=pimp wrote:Need some advise.
Fuel pressure???
Bad coil pack? or bad spark plug maybe.
HotWIRED
Sounds like the engine is being flooded. But I would also check for clogged fuel filter, low fuel pressure, vacuum leaks.
240+civic=pimp
replaced all the coilpacks, spark plugs.
Fuel pressure was at 40-50 psi at idle and at WOT.
ECU?????
Eikon
Car: 71 240z, 93 Supra TT
Maybe ECU... Maybe MAF? Is it reading airflow correctly?
What would happen to fuel pressure if your TPS sensor went bad?
240+civic=pimp
I unplugged my MAF sensor and it still ran like ****.
how could i test the MAF?
TPS sensor is good.
I have an ecu comming from mckinney.
I had to pay 200$ though
goofynick6
Car: 1995 S14.5 RB20DET
Try unplugging your oxygen sensor. If that didn't help, try unplugging the TPS sensor.
240+civic=pimp
I unplugged thwm both at idle.
O2 did nothing and tps made the car want to die
Joe
240+civic=pimp wrote:I unplugged my MAF sensor and it still ran like ****.
TPS sensor is good.
lol dont unplug your maf that will create a world of other issues.
clean your maf sensor, rubbing alcohol, a q-tip and a GENTLE hand. let it dry, try again.
Carl H
timing is off i bet you 5 dorra.get a gun on it and come back with the results.
240+civic=pimp
I never adjusted my timing. This just started after i upgraded some parts!!!!
goofynick6
What parts? FMIC?
SillyRB
Check the following, didnt read the whole thread so i dont know what was said. sorry.1) PCV could be clogged2) TIMING, CAS, ETC, make sure its @ Base3) Fuel Pressure
240+civic=pimp
I upgraded turbo injectors and went to a bigger FMIC and piping.
I have a spare CAS i could try.
fuel pressure was 40-50psi
goofynick6
On that note...good luck!
Carl H
240+civic=pimp wrote:I upgraded turbo injectors and went to a bigger FMIC and piping.
or you could take some freeking advice and put a timing light on it and see where your base timing is...........your base fuel pressure should be 43 psi with vac line disconnected.
240+civic=pimp
What is the easiest way to do this on the rb.
240+civic=pimp
I recieved my new ecu last night.
Im going to install the stock injectors clean the MAF and install a new ingnitor, the eiring and coil packs.
If this fails ill read my rb manual and check the timing.
Hope this all works.
Eikon
Good luck man!!
Hey, when you figure out the timing thing... do you want to meet me in Oshkosh sometime and teach me how to do it?
240+civic=pimp
Sure thing, I bought the full service manual on the rb20det R32.
I should be able to figure it out.
240+civic=pimp
Alright, The new ecu makes the car run perfect!!!
Thanks for the advise guys!!!!
