Studder under boost
rbveilside240
Hey guys, me again--when i turn my boost up, around 9-10 psi a studder develops. I have checked all the lines and there is no leak.? What could be the problem?
Slo_240sx
Car: Mean Green LS1 S13. Caged and Backhalfed.
Boost leak somewhere. Recheck your I/c pipes... You also might be maxing out the MAF.-Alex
rbveilside240
so you think I need a new MAF if that is the problem or will a AFR fix this?
klh6686
Car: '92 FB stock daily
'90 FB w/ RB20
'92 FB w/ VH45
do you still have the stock turbo? if so i highly doubt you would be maxing the maf out, but if you have an upgraded turbo its possible. The easiest thing to check first is to make sure that you have some quality ngk plugs in there and that they are gapped properly. Factory they come 1.1 mm but it is recomended that you get .8 mm for higher than stock boost. Good luck.
rbveilside240
Got brand new NKG type R plugs. How do I know what the gap is?
Joe
you check with a plug gapper
99 cents at autozone
JonPowell
Car: Cars, Music, My family
Your timing may be too far advanced for that amount of boost also...you may be detonating and the knock sensors are pulling timing on ya.
rbveilside240
I havent had a chance to check the spark plugs nor the timing, but today I found that there is no studder if I let the boost build up at half throttle, but when I press the petal to the floor, it begins to studder....Any more thoughts?
JonPowell
Same thoughts, try what we suggested first, then look for more options.
rbveilside240
guess it was the spark plug gap,it was sit at 1.1, I gapped it a .8, took her for a spin and it studder a couple times, then hasnt done it since----THANKS GUYS
