studder @ low rpms... help?
SoDelMotorsports
Car: S14 Zenki
hey whats goin on, the car im having the problem with is a 91 240sx with ka motor... automatic trans.. lately this has been getting worse little by little, it started off with just a quick studder every once in a while only while i was stopped with the motor under load like a red light or stop sign, now its been going into low rpm (-2.5k) accelleration with a sputter one after the other sometimes, but its getting more frequent... anyone have this same problem and maybe have the fix? thanks
mexicanracer03
Car: 95 S15FRONTEND SR20DET and 97 2JZ GT4294/ 93 SC300 Black/ 95 SC300 Green
check you spark plugs, cap and rotor button. and then check and see if you have a broken or loose vaccume line.
