Mikey_ZX »
https://forums.nicoclub.com/mikey-zx-u162767.html
Sat Feb 19, 2011 4:42 pm
I was able to remove the tensioner and upper pulley studs with no problem at all. However, when I tried removing the lower pulley stud I was able to turn it a few times until the stud froze and broke on me. This was one of the hardest bolts to remove from my block, I basically tried using an easy-out, and the only thing that worked was drilling to the point where only half of the diameter of the stud was left and using a long screwdriver to smack it loose. So, in the process of removing my broken stud I smoothened out a few of the bottom threads in the hole, I've inserted the new stud and it wiggles as it sets, however I haven't inserted the stud fully. I am asking what is the strongest application I can use to keep this stud still and free from wiggles??? Any suggestions will be appreciated!!!
