chachi longshot wrote:Umm, you do know the 2JZ-GTE motor isn't a 4cylender, right? It's an inline 6, just like the RBs. And it is a damn strong motor, just expensive as hell to work on.
With the information and knowledge he has given so far, do you really think he's that stupid? He is speaking about that motor because it is comparable to the RB series engines. Both I6.. both turbo. Get it?
Anyways, I heard the words "unlimited potential" and "flat four" in this thread. This is obviously getting out of control. No engine has unlimited potential. The STi engine may have some decent potential.. but definetely not unlimited. I do think it is comparable displacement wise, but in the end of all modifications, the RB F/I engine is going to overcome basically any 4 cylinder F/I engine.
So lets get further into detail. I don't think it is being understood that having two extra cylinders is also a big advantage - modified or not. And what's even BETTER, is that it is a straight 6 cylinder. Honestly, I think it's safe to say a straight 6 cylinder engine is more "balanced" than 4 cylinders, which makes it better to modify. Its configuration makes it an almost perfect engine design, which is why people have squeezed big amounts of power and torque from them.
If you want to know exactly what I mean - they have a longer crankshaft with more balanced rotational force (I'm speaking about counterweight offset here in relation to the stroke timing of each rod/piston if you didn't notice), and that makes them so much stronger than a 4 cylinder, even after modifications. So despite the fact that the displacement on a straight 6 cyl and a 4 cyl may be the same, the straight 6 cylinders design makes them superior and stronger. That is the biggest reason you can make so much more power on them than a 4 cylinder.
So...., my point is that the RB engine, along with its design, is really not comparable to any 4 cylinder when modified. It WILL overcome a 4 cylinder in the end. And I think J-Spec Tuner would agree.
This is why I have decided to forget the MR2. Well there are a few other reasons actually. And it's not because I dislike 4 cylinders. After all, I drive a well balanced engine right now capable of 8400 rpms....
