Stuck up lights....
fastclown
Car: '91 240SX, '67 Turbo Mini, '63 Woody Mini, '63 Minissan ZSX 6, '84 300ZX
I'm sure this has been covered many times but the info section didn't solve it and I couldn't find past posts on it... So, I did what the manual and site said and they come back up and stay there. Since the motors and the linkage work fine, which switch is bad or could it be a relay... It's a 1990.. Please advise. Thanks!Mike
onosqv
Car: '92 240sx Vert
It may be a relay.
There are 4, I believe, 2 for each motor going up, and 2 for each motor going down. Located on the driver's side fuse box near the light. If you are running a stock intake system, it's below the intake box.
Worse comes to worse, you are going to have to multimeter trace the wires to see where power stops getting supplied.
