Stuck Throttle/Gas Pedal
emiliog2276
Car: 1990 300zx 2+2 NA
2002 Nissan Sentra GXE
Sometimes when i come to a complete stop and accelerate after my throttle gets stuck and I have to slam on the gas pedal in order to get the car moving again. Does anyone know the cause for this? I've found some post that recommend cleaning the throttle bodies but i just did that a couple of months ago.
Zwicked
Car: 1990 300 ZX tt, 1990 240SX
There is a PVC tube on the top valve cover right by the throttle bodies. Often it comes loose and works it's way out binding on the TB parts. Just open the TB's by hand and watch next to them.
Also it can be a worn throttle cable
DankZX
Car: 1991 N/A 300ZX: Few Mods
1996 Sentra GXE
I had the same problem, I would go to accelerate and the gas pedal would get stuck because the driver side PCV pipe was catching on the throttle body. I zip tied it and has not happened since.
White_Knight
Car: 1990 Nissan 300ZX 2+0 Non-Turbo
I have been having the same issue with my 300zx. I'm going to definitely try taking a closer look tonight at the T/B and the physical pedal area, because the pedal sticks even with the car off. So i'm hoping it's a minor issue.
gnozahs
This is an easy fix.Just clean out your throttle bodies with a toothbrush or wire brush(make sure it can fit into the TB) and some carb or throttle body cleaner and do what they said about the PVC thingy.
White_Knight
Awesome! I'll check this out tonight. That and seeing if the butterfly's are hitting anything.
thanks!
White_Knight
Hmmm... cleaned out the T/Bs, and no difference. I can't see it stuck anywhere... the PVCs i'm not noticing having a problem. I suppose i could post a pic tomorrow of the assembly... maybe there's just something i'm not seeing...
Brutus864
Car: 90 nissan 300zx
I'm having the same problem have to stomp the gas just every once in awhile to get it freed up. Just does it sometimes and my TB is cleaned and nothing hanging on the cable.HELP what in the hell is it lol
ZL8NING
Car: 1993 300zx 2+2
Blast from past! 5yr old thread!
Thanks though. I have the same issue, so now I know what to do!
ThisIsSparTTa
Car: 91 300ZX TT 2+0
Have you guys tested and adjusted TPS? I would start there. http://z32.wikispaces.com/Throttle+Position+Sensor
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Holy thread jacking/resurrection Batman!
